Magnum 500's
Magnum 500's
Hi guys...
Can anyone help me here...I cant measure my own wheels 'coz the car isnt here but... need to find out in inches the measurement between two nearest bolt holes on a 14" Magnum 500 rim and also the diameter of the center hole..??
Cheers in advance!
newport100
Post by newport100 »
Hi Steve
Sorry- Cant answer- but have you sold the Dodge???
Na still got it!!
newport100
:hello1:
They measure 4 & half inches across No 1 & 3 studs , or 3 & 5 stud , or simplified , miss a stud when measureing.
What would be the best way to explain it? , as it's got me going now. :help:
Me number TWO on the keypad don't work. :roll:
On a 4.5" pcd wheel (which yours should be), the centre distance between 2 adjacent bolt holes is 2.65" or 67.2mm
Adam, the 4.5" measurement is the diameter of the circle that the studs are arranged on (pcd - pitch circle diameter), so the distance between 1 & 3 for example would be 4.28" or 108.7mm.
So there.
:D
5 lug patterns.
Measure from the center of one stud hole, skipping the adjacent hole,
to the outer of the furthest stud hole.
ie X = 67.2mm
and dont forget the .2 :roll: :lol:
Thanks Kev, I thought I'd heard of a way of getting the pcd measurement from measuring across 2 studs, but couldnt remember it #-o
Or!
Use this diagram. And do the following calculation;
5 Stud PCD = S divided by 0.5878
or.....
S = 4.5 (PCD) x 0.5878
= 2.6451 :thumbright:
RobTwin wrote:ie X = 67.2mm
Is that some sort of foreign measurement?
Mine measures 2 11/16".... :roll:
Or, centre of hub to centre of stud and double it (as there isnt a stud directly opposite)
RobTwin wrote:On a 4.5" pcd wheel (which yours should be), the centre distance between 2 adjacent bolt holes is 2.65" or 67.2mm
So there.
:D
[-X that's a millimeter out Ivor :roll: , sorry, 1/25 (ish)" out - you'll confuse the poor lad :wacko:
