Gear drive of chain?
Timing Gear - What is the best??
- dustymopar
Timing gear, what is the best.......
Enough is never ever enough....
Rollmaster or 440 source billet, I can highly recommend as being good quality and needing no adjustment after having lined up the dots and checking with a degree wheel. Cloyes are the absolute pits, had loads of trouble with them, use at your peril! A good quality chain is every bit as good a gear drive in my opinion.
- Dave-R
I use a JP Performance multi-keyway timing set. Found it perfect and not a bad price.
http://www.jp.com.au/Performance.html
- dustymopar
- mopar_mark
I'm using a multi keyway rollmaster with thurst bearing behind
from romac in Oz
www.romac.com.au
tiz nice and i've had no issues
gears make a racket that sounds good for the first 500 miles
and then is a pain in the ass
and you can transmit harmonics from crank to cam that have a detrimental effect on anything that runs off the cam. i.e in some engines the dissy and oil pump. if the dissy is gear driven rather than offset dog a Nylon gear can help mitigate (i don't know about anything other than my own which is gear driven)
you could go for gilmer belt drive just to be different
need special pulleys and water pump covers and a good bit of space
and a tensioner
from romac in Oz
www.romac.com.au
and a tensioner
