The Project (Old race cars never die)
Nothing to see Pete , the two oil feeds on the base of pump (oil filter plate) have been plugged.
No problem with drain back , motor was sitting for 3 weeks & she primed up on the starter motor.
If you're spinning the motor to 8k then a twin oiling system will be in order , this set up works for me ,will also monitor oil pressures too , maybe the guinea pig motor.
Sorry chaps
Point 'A' connects to point 'C' , 'B' being capped off , this puts the oil on top of pump , hence the oil can't possibly syphon/drain back to sump , whichever way the line is routed.
The oil feed in the sandwich plate is 1/2" @ it's smallest 9/16th @ it's largest , the oil line from pickup to pump is also 1/2" @ it's smallest (fittings) , oilways in the oil pump are no bigger than 1/2" if that , the standard pickup tube in block is 3/8th or 1/2" if using internal pickup , so this sandwich plate is plenty big enough for the external oiling system when using single oiling.
Most battery drills won't/can't spin the pump fast enough to prime the oil , unless you got an electric drill you got a problem @ the track , i had to find an alternative , priming the oil can be a PITA.
