PCD....
Jeff
PCD....
Post by Jeff »
Am I working this out right?
These are unilug wheels. I estimate they will fit 4" to 5" PCD. Am I right or wrong?
Anyone help?
Normally unilug wheels fit 4 1/2" to 4 3/4" PCD, which wheels are you looking at?
Jeff
Post by Jeff »
these...
that isnt how you measure em, you have to take a measurement then calculate the PCD from it. (4 stud wheels you can just measure em)
They look bigger than 4 1/2 . Might fit 5 1/2? (dodge pickup etc)
Jeff
Post by Jeff »
Right i have worked that to 4.5 center to center after formula (thanks Blue)
But I wonder how small they will go to. Will they go down to 4"?
DaveBishop
Post by DaveBishop »
Jeff the problem is with the unilug wheels is that you will be able to fit the wheels on but you wont be able to get the wheel nuts on. I know this having had a few A bodies with the 4in. stud patten. I will be getting rid of my front discs off my 1969 dart soon which are the 1973 4 1/2 pcd and the rear axle was redrilled to the 4 1/2 pcd as the is enough meat on the flange. If you don't want to do that I am sure cannonball or someone must have an old 8 1/4 axle somewhere that they don't want
2 x 1969 Dodge Darts
TrevD
Post by TrevD »
jef, botom line is those wheels cant be safely used on a 4"pcd thare wont be enough metal arround the hole to be safe.
too much is never enough
Guy
Post by Guy »
DaveBishop wrote: I will be getting rid of my front discs off my 1969 dart soon
Dave if if Jeff does not have these off you give me a shout. I need, I want =P~ :thumbright:
DaveBishop
Guy I you can have fist refusal after Jeff. It will be the top A arm and the knuckle as well as the disc As to fit them to a pre 1973 car you have to have all those bits
Jeff
Post by Jeff »
Dave let Guy have em..... Mine aint a keeper, Guy will make far better use of em.
DaveBishop
ok mate
