4 speed Draggin
newport100
4 speed Draggin
Post by newport100 »
Ok
Gonna make an arse of meself this weekend at the Pod at the RWYB- going to watch Adam & Alan and will have a crack at it just to see what the Challenger does- any tips regards the 1/4 with a 4 speed manual?
:atthemovies:
Shift as quick as you can? :clown:
newport100
mm- apart from that?
Got a 8 K Tach witha shift light- althouh its disconnected-
do these help (really?) :help:
Fit a line lock, or an extra leg :thumbright:
BUDGIE
Post by BUDGIE »
Have a chat to Mick70RR Mark ;)
You deffo want a shift light/limiter
Drop some pressure outta your street tyres and fry em in the box.
Make sure you've got a tank of "optimax" or eqv.
Prey you don't break summat :thumbright:
4 speeds are not called "parts breakers" for nothing.
I had one in the Sox, and they are very hard to get off the line as they lack the torque multiplication capabilityof an auto. Mind you, that was with slicks. I was "side stepping" the clutch at 5200rpm.
If you have street tyres, it is more likely that you will suffer wheelspin as opposed to "bog". I would baby the car off the line and then nail it - it is not as exciting but will probably get the best results (times) on street tyres.
Option b) - buy a cheap race car and Bananarama! (with an auto in it) :thumbright:
newport100
Thanks !
Ill give it a go- softly softly at first- see what happens!
(Note to self- Take AA Card on Sat)
AllKiller
Post by AllKiller »
Good luck, never got out of the box without wheelspining my manual, even coming out easy then nailing it got huge wheelspin and crap times :roll:
ALL KILLER NO FILLER
Time to invest in some Hoosier Quick times :thumbright:
Mick70RR
Post by Mick70RR »
I just leave the line as fast as I can without lighting the tyres up. Doesn't work very often as you can see here.
newport100
:shock: :D
Looks like Im in for a fun day out anyways!
Mick70RR wrote:I just leave the line as fast as I can without lighting the tyres up. Doesn't work very often as you can see here.
:D
Love that clip.
newport100
Id be happy to get within a second of that! :roll:
Pete wrote:4 speeds are not called "parts breakers" for nothing.
I bought the manual off Pete and the effect of "side stepping" at 5200 was evident on the clutch steel plate- the metal was smeared like plasticene :shock:
I chickened out and swapped it for an auto :oops:
newport100
Soooooo..... :dontknow: Sat looks like its gonna pan out like this?.. :runaway!: :working: :thunder: .................... :pub: :tongue3:
