Saturday he checked over all the pistons and rods noticed i had lost the molly off a couple of top piston rings so they were file fitted and replaced pasigauged rod bearings and reassembled, all the bearings were polished with 1000 grit.
So it was just dial in the cam and finish assembly we decided to use just a single oil line system and checked it out and it primed up straight away loads of oil
So ever thing looked good changed all the burnt puhrods and broken lifter cleaned up the damaged rockers.
By this time it was early evening people were starting there BB Q's so decided to put the motor in the car so it was all hands on in it went even had 10psi oil cranking
But all in all a really good weekend, I was going to take loads of pics but was so busy didn't have time. So big thanks to every one who helped out with the build and the advice
