Can someone check my calculations please?
I'm about to order my wheels and tyres:
Front: 15x7 with a 3.5" backspace - tyres: 235/60r15
Rear: 15x10 with a 4.5" backspace - tyres: 275/60r15
Opinions? Advice?
Cheers.
Opinions? Advice?
Cheers.
Might have a problem with the Bananarama! the arches , i've got the same rear combo on mine (black windows)with 275/50/15 , i run caltracs so can get away with it , 60 profile will cause problems , 50 profile may work if the springs are good.
Some get away with it using air shocks , you really don't wanna go down that route.
Sorry i did'nt give you the info you wante to hear , a great lookin wheel though , i normally run TT2s , when i get bored with em i swap over to the black windows , completely transforms the car , looks mean.
Checked the rear tyre size , there 275x60x15 , don't think they manufacture the 50 profile for that tyre , Budgie will know.
You might get away with it if you have the rear springs retempered & 1 1/2" to 2" added to them , or maybe empty the boot , carry no passengers & run the fuel tank on near empty.
Been there done it , eh Bob,
Just as a point of reference the tires that are on are:
Front 205/70 R15
Rear 235/75 R15
These are all wrong I know, that's why I'm changing them but as far as clearance/height goes I think I'll be ok.
I just need to calculate backspace for the rears. I originally thought 4.5" on the 10" rims at the back but I think Mick70RR may be right and I need to go 5.5" bs on the back. I'm still calculating
Cheers for this stuff fellas, it's good to have the benefit of all your experiences.
Front 205/70 R15
Rear 235/75 R15
Just a thought , if you go with the 5.5" backspace , then you will loose the 'full look' on the rear , will only be an inch different than stock look , a few of us have got away with fitting 10" rims with 4.5 back space , come to think of it
my TT2s have a 3 3/4 back space , never had a problem with the black window 4.5 back space , sooooo , forget all my last posts & get those black windows.
