Dumb question
Dumb question
As the title says but i'll ask anyhows. :roll:
The Pit has managed a best of 1.6 60ft with a noticable bog on the hit , now sorted the bog (excessive purge line to solinoid length :roll: ) , just wondering what it might pick up. :dontknow: ie: if it picks up a tenth on the 60ft does that equate to 2 tenths Et? all else bein equal.
Just need that tinsey winsey bit out of it. ;) :D :roll: :read2: :read2: :working:
Either it's not a dumb question, or we're both dumb :geek: as I've been wondering this meself for a few weeks too.
Our best 60ft is a pathetic 2.19 :roll: - as I've mentioned before, that was on the BFG's with not much heat in them, easing off the line for the first 20ft or so.
With a best of 13.65 @ 104, we know it's capable of 12's with that mph, so if we could shave off, say .5 from the 60ft, does that mean .5 off the e.t.? Or more?
Presumably the mph would go up a gnat's, too? :read2:
Rob , you could probably pick up a tenth if you stopped combin yer hair & takin piccys of the stands.
:D
Are you confusing me with another black 68 driver? :-k :help:
Mick
Post by Mick »
I thought that 1/10 at 60ft, equated to 2/10 at the 1/8 and 3/10 at the 1/4.
Mick
Mick wrote:I thought that 1/10 at 60ft, equated to 2/10 at the 1/8 and 3/10 at the 1/4.
Mick
Could be about right that Mick. At least if the acceleration is fairly consistant.
Good 60fts do seem to make a big difference because your speed at any part of the track will be increasingly higher as a result.
Mick
Works for me.
Time to toss those "gay gears" away Adam :evil:
Ian Z
Post by Ian Z »
anyone had any like-for-like experience of changing gears? ie, same setup, different gears tried.
wot is it wiv you southerners. Thats the second time 'toss' has been used this week. :D :?
Involuntarius peristalsis rectum
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
<a href="http://www.mybannermaker.com/" target="_blank"><img src="http://img153.imageshack.us/img153/1862 ... cebsh4.jpg" alt='Create your own banner at mybannermaker.com!'></a><br>
Went from low 12s to high 11s with a change from 3.91 to 4.10. Would have to look for the slips to see what the 60fts were but I think Linda still has them.
But i also improved the fuel supply in that time.
Ian Z
Post by Ian Z »
Dave, that seems a big change ~1/2 sec. Do you feel/know that the fuel added any? What was the fuel mod? Tyres same, air quality same etc? Be good to see 60ft difference.
Ian Z
Post by Ian Z »
shift points same?
Ian Z wrote:Dave, that seems a big change ~1/2 sec. Do you feel/know that the fuel added any? What was the fuel mod? Tyres same, air quality same etc? Be good to see 60ft difference.
Picked up around 4 tenths. Better fuel and air delivery plus the GV unit. But otherwise exactly the same.
SORRY!
Dumb ass me. I changed from 3.91 gears to 4.30 gears . NOT 4.10s. that was a brain slip. :oops:
Ian Z
Post by Ian Z »
thnx Dave.
Adam, what rear gears you got. I know you have GV (extra weight! ;) ). I'm still with gay 3.23 and 1.7 60ft pb on shlicks.
Ian Z
Post by Ian Z »
Dave, how does it work then? Low 1st on 4.30, 2nd, 3rd, then OD the rest ?
