This is amazing.
It shows 24 hours of air traffic for the whole globe.Each dot is a flight. You can see the typical transoceanic routes used,etc. Play it a few times, look very closely and you can see theday/night boundary moving and how the intensity of the flights increasesduring daylight around the world. Our current statics show more than21,000 heavy transport airplanes flying world wide and just under 60,000flights per day world wide.
Wow, way cool.
http://radar.zhaw.ch/resources/airtraffic.wmv
Mark H. Smith
Boeing Air Safety Investigation ATF
Air Traffic
- latil
Something like 200 tons of fuel to fly the Atlantic for one 757.
Hundreds of thousands of TONS of pollution every week,most of it put out in the upper atmosphere where it does more damage. Plus the heat emmitted,plus the fact that every gallon burnt equals a gallon of acidic water vapour.And we wonder why there is increased rainfall.
Carbon footprints.
Move with the times you lot, it`s the 21st Centry...........they probably said the same thing about polution when the 1st steam train ran.
By the way, if the weather at this years "NATS" was the outcome of global warming..................................count me in cos I`m all for it.
OOPS...........................nearly forgot
Re: Carbon footprints.
Well, here's to Global warming then. Hopefully Santa Pod will be moved to higher ground by thenR.RUNNER wrote:Move with the times you lot, it`s the 21st Centry...........they probably said the same thing about polution when the 1st steam train ran.
OOPS...........................nearly forgot![]()
if the temperature of the seas rises by another degree, the gulf stream will stop hitting us and end up going to iceland
iceland will become mudland
we will have Ice age like winters and the summers will be monsoon.
erm.....its started
the sahara dessert will engulf much of southern spain and italy
I do try to be a ray of sunshine when i can
Nice
erm.....its started
Nice
