68 Charger. Engine swap. THE END.
I know many of you know the car.
68 Charger, lots of options but a 318 engine (Belgium car. Quite common apparently to spec 'em up and then drop the small engine for European market)
Anyhow - Clearly she needs a 440 and I have spent the last couple of years dealing with the cosmetics (the chromework, the interior etc etc) so she now looks something like how I want from the outside.
Long story short - Bought original 440 'the pit' engine from Brutus (before he caught 'the bug' and went power loopy) with a view to getting Blue to help me with a single weekend 'out with the old in with the new'. However, as with the best laid plans etc things moved on a bit.
Finally got round to pulling the thing but I think I keep finding things that I will 'just do while its out and easy to get to'...
Thought it might be amusing to some of you is all, so will post a few pics as I go along. I am aware this is small beans to some of you out there, but to me its a big undertaking and I am learning as I go. Hey - we all have to start somewhere right ?
My aim is not for a concours classic - its a 'looks nice from 10 feet' charger with the 440 she deserves...
Enjoy. Will try and keep updated.
So , while I'm at it I am now seeing the rusty bits under the hood.
Not mega - usual rusty battery tray (which I patched last year) and a couple of crunchy bits round the susp turret and behind the hinges.
You can guess what happens now. "While I am at it, I may as well do those". Pics show the bubbly stuff I cut out and ground down. Will get a little plate welded in and ground down - you will never know...
As usual 40yr old bolts can be tight, and as usual the head came off one. Lost a couple of hours drilling that out.
Also cut out some bits round the turret where they were crispy. The stuff behind is solid, so again a horseshoe shaped plate needs to be made, welded, ground down...
So - I'm waiting for the welding so I decide "You know what - I better do the underside whilst the exhaust is out".
I begin scraping...
Been at it a week now, and done about 2/3rds I think. Here are a few in progress. I have been really really happy so far - I expected to find some horrors but it seems the oils, lubricants, fluids and goop over the years have really kept her solid. Excuse photo quality. Key thing here is its all metal.
I am going to treat the insides of the box-sections, POR15 the outside of the boxes (rust proofing metal restoration paint stuff) and the stonechip/waxoyl the flat panels and trans tunnel.
This is as far as I have got at the mo - so heres the last pics. Metal floor. I know I am easily pleased, but its better than chicken-wire and filler right ?
I begin scraping...
You should consider yourself lucky that Blue didn't get too involved there Morgan...your interior would have gone over the hedge, together with "500lbs of worthless tinware" and before long, the lightweight panels would arrive!
That's already a good looking car, once that rip snorting motor is in...wahey!
Apparently not for the Charger. I know you do on some of the others.
Blue was kind enough to spend an hour or so with me when I first got it to help me kit out all the bits I need from 440source. (all the ancills needed, pulleys, brackets, that sort of thing). New engine mounts and she will drop into the original frame.
Expect a much longer post if it doesnt
Yep - should have mentioned that.
Engine bay will be gloss black.
Engine block will be silver.
Engine ancills will be Chrome (filter, rocker covers)
Not to everyones taste, and certainly not traditional - but car is already a bespoke colour.
I think that a gunmetal Charger with a black and silver engine bay will look fantastic... Each to their own and all that.
