Parts
Parts
All got to
Precision Performance Hose Ends
2 x -12 90* £10.00 each
5 x -10 90* £9.00 each
7x -10 45* £9.00 each
5x -10 straights £8.00 each
2x -08 45* £8.00 each
1x -08 90* £8.00
3x -06 45* £7.00 each
1x -06 90* in black £7.00
1x -04 straight £4.00
4x -04 45* £5.00 each
4x -04 90* £5.00 each
2 x 3/8th hard line to -06 straight male (trans line adaptors) £5.00 each
5 x 3/8th hard line to -06 straight female ( as above) £5.00 each
2 x -06 to -06 45* female connectors £4.00 each
1x -06 to -06 female short straight connector £4.00
2 x Holley -06 long carb adaptors £6.00 each
1 x Demon -06 long carb adaptor £6.00
2 x Holley -08 long carb adaptor £7.00 each
7 x Holley -08 short carb adaptors £5.00 each
Demon -08 carb adaptors 1 long, 1 short £8.00
9 x -08 male T's £ 4.00 each
2 x -08 male to -08 female 90* £4.00 each
1 x 0 to 15 psi fuel regulator pressure gauge £8.00
1 x 0 to 30 psi fuel pump pressure gauge £8.00
Lots more fuel fittings, if anyone wants the lot come take a look and make me an offer
Raybestos 11x3 front brake shoes Part# 336PG £35.00
Raybestos 11x2 brake shoes Part# 280PG £30.00
B Body 66 to 70 front parking brake cable Raybestos BC92323 £20.00
Northern heater core, 70 to 74 B&E Body with aircon £30.00
Master Cylinder B body 67 to 70 with front discs, engine side outlets £45.00
Master Cylinder 73 to 75 A body with 10" drums £25.00
Alternator, double pulley, up to 70 £35.00
Alternator as above, broken brush £15.00
1 low beam,1 high beam £4.00 each
Rear diff rebuild kit 742 case £50.00
22 8 3/4 crown wheel bolts £18.00
34 3/8ths torque convertor bolts £20.00 Genuine Mopar
A&A 727 band strut £10.00
727 filter spacer £15.00
727 rear racing band £20.00
SFI approved flex plate 6 bolt crank £25.00
727 band £10.00
BHJ torque plate B & RB £80.00
Mopar performance breather P4529880 £8.00
Mopar performance rocker cover grommets pack of 7 £10.00
66 to 70 B body & 69 A body heater hose bracket £4.00
Demon rear bowl jet extension kit £5.00
MSD advance kit Part# 8464 £10.00
4 x FBO MSD advance bushing kits to give 10 and 14* £15.00
Competition Engineering back half cross member, 2x3, 60" long with a 3 1/2" drop £30.00
440 mechanical tach drive electronic distributor £35.00
Holley 4150 sec diaphragm kit part# 20-13 £8.00
used 400 timing cover £5.00
used 400 rocker covers £5.00 later type
rocker shafts with rockers £5.00
Guy
Post by Guy »
Hi Neil what in the 742 rebuild kit pls
Guy
just checked and noticed I've stole the pinion seal out of it
so contains pinion bearings, crown wheel bearings, pinion nut, marker and sealer
£40 due to no seal
dustymopar
Post by dustymopar »
Neil, Put my name down for the Competition Engineering back half cross member
Ta :thumbright:
Enough is never ever enough....
Mine please!!
dustymopar wrote:Neil, Put my name down for the Competition Engineering back half cross member
Ta :thumbright:
ok mate
db wrote:Mine please!!
OK Mate
Boz01
Post by Boz01 »
'1 low beam,1 high beam £4.00 each'
Yes please! :thumbright:
'You can never go fast enough!'
1966 Dodge Coronet 440 c.i.
1969 Dodge Dart Custom
http://www.americansuperstock.co.uk/
Niel have you got any FBO electronic ignition systems? If so how much?
Neil i'll take the A bod master cylinder for 10" drums. Give you a call later.
marc-jerryatric wrote:Niel have you got any FBO electronic ignition systems? If so how much?
Yes I've got FBO ignition kits
£125.00 inc vat
includes
ECU
Coil
Cap (brass contacts)
Rotor
Ballast
Tuning guide
Excellent goodies, thanks Wil :thumbright:
GranSport
Jeep Voltage Regulator required
Post by GranSport »
Hi Neil, is there a number I can call you on?
Thanks
Edie Cross
07798 614931
Don't even know if he is still a member?
If you are after FBO stuff then look up Turnip on here.
