Oil reservoir
Jon Connolly
Oil reservoir
Post by Jon Connolly »
Was thinking about fitting a Moroso oil reservoir at the same time as my System1 remote filter to give me a bit of piece of mind if I had a complete loss of oil pressure half way down the strip. If I have 3 quarts of oil in reserve I might stand a chance of stopping and saving the engine.
Was going to control it via a normally closed oil solenoid switched with oil pressure switch ( break on fall of pressure ). At the same time as this activating I was going to cut the feed to the ignition via a relay and light a big red light so I knew I had experienced a loss of pressure.
Can also use this as a pre oiling system for start ups after long storage periods.
Anyone doing similar ??
andyrob
Post by andyrob »
completely different car, but i run a auqasump in my peugeot 306 touring car, which is used to lube the head before start up & give you a few second life line if you bust the sump.
Ill try & find some info :read2:
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
andyrob
Post by andyrob »
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
Jon Connolly
That`s the sort of thing
I have bust a pick up on a small block before and didn`t know much about it at the time
Never used an Accusump but often considered it, I especially like the pre oiling feature.
Mark uses one on his Hemi Cuda as a pre oiler and I j know he is happy with it I fig its ok for a road car to me it's extra weight.
Knightcharger wrote:Mark uses one on his Hemi Cuda as a pre oiler and I j know he is happy with it I fig its ok for a road car to me it's extra weight.
that extra weight dont matter a Bananarama! if it saves yer mtr, ;)
what did you find in your b1 bob?????
jerry
Post by jerry »
Yes, I (Mark) use one, been very happy, I like the fact I can pre oil before cranking, which was the main driver for me getting one.
Jon Connolly
Decided on the Canton Accusump, as the pre oiling looks easier to wire up using their ecs valve ( combined pressure switch and solenoid ).
Will drive something like this latching relay which will permanently kill the ignition and light the warning lamp until physically resetting.
http://uk.rs-online.com/web/search/sear ... &R=0350377
DaveBishop
Post by DaveBishop »
Real Steel use to sell the auqasump
2 x 1969 Dodge Darts
Still stripping down Dunc, looks like the valve guides were loose and oil got into 4 of the chambers and chirped 4 of the pistons.
the heads and valves were ok and the bores look good so it is a set of bronze valve guides and a set of pistons so far.
thats Bananarama! bob i did not expect a piston job for you
GTXJim
Post by GTXJim »
Who's doing your head work Bob, I can highly recommend Len at the Cylinder Head Shop He did a great job on my Indy's :thumbright:
http://www.cylinderheadshop.co.uk/
Hell Yeah!! I'm a Redneck
Motor never smoked on start up or decel , so would eliminate valve guides/seals from equation. ;) , seals should hold oil from getting into chamber regardless of guide wear , get a dip stick/sight glass on that motor on rebuild.
The Plodge shot its load at the top end of the 'Pod today.
Looked like a major blow up from the tree end.
We got it home, turned it by hand with no issues, changed the filter, pre-oiled it - 75psi, no leaks.
Re-filled and it runs as sound as a pound.
The car is COVERED in oil, including the slicks :shock:
It will take days to clean but it would appear there is no engine damage (time will tell if it has shortened the life of the bearings).
The Oil warning light flickered on the tach and Roydon hit the kill switch and coasted.
It would seem that the spin on filter "O" ring seal caused the problem.
Given Blue's thread on filter issues and the idea of an Accu-sump in this thread it would seem that more belt and braces is not a bad idea.....
One final thing - they were harvesting next to Royson's house and the car looks like its been tarred and feathered!!!!!
