Tig's Slow Motion Launches
A couple of video's from the weekend posted on my message board from Tig.
Woohoo, how the hell does it stay in a straight line with steering like that :D
steveo
Post by steveo »
thats some good video action 8-)
Rogue Trooper
Post by Rogue Trooper »
:shock: Holy cow
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
NaughtyAlan
Post by NaughtyAlan »
:shock:
Trigger_Andy
Post by Trigger_Andy »
:shock:
Is that normal?
It's a clear argument for poly control arm bushes is what it is.
Rubber is fine my backside.
Jon Connolly
Post by Jon Connolly »
Blimey
:shock:
Brian J
Post by Brian J »
Just imagine what it would be like with a quick car
Brian J wrote:Just imagine what it would be like with a quick car
You do know he is fitting a Procharger next? ;)
No Rubber bushes here. We have adjustable tubular uca's on heim joints, Alloy adjustable struts also on heim joints (at the "K" end). The only poly bush is in the lca. Figure it needs a good set up. We got +5 castor, 0 camber and 1/32 toe in @ +1 ride height but the hub arms where heated to bend them up when I had a different set up. Car is stable at speed but cross winds will effect it. Best MPH is 142.5 and @ 3830lb race weight approximates to a 850ish HP motor. Thanks for putting them on the MMA site :thumbsup:
It feels like the wheel hardly moves, I know it shakes but it's all over quick in real time :lol: . Think I'll be replacing the steering box and the drag link idler arm over winter. I really need to get the chassis sorted before the procharger goes on. Though tagging it to 7.50 is a whole different ballgame :roll: .
Oh and if here's some slomo of Paul Rossi's old superstock challenger it does the same thing. Apparently it's a common problem with stock style mopar suspension. The only way to truly eliminate it is to go to a coil over strut front :cry:
Cheers.
Tig
WOULD FITTING SOME SORT OF STEERING DAMPER HELP,
but as tig said its all over very quick in real time
DaveB
Post by DaveB »
Looks scary when it lands,Mines totally stock on the front apart from 90/10 shocks,but saying that doesnt pull a 3ft wheelie =P~
Might be them bias belted general grabbers on the front Tig
Seems to be a common problem, I have seen video footage of Hemi Dart and Barracuda super stock cars doing just that.
can the caltracs not be adjusted for a milder hit,
as i understand it wheelie looks good but compromises the et ????
Brian J
Post by Brian J »
Cheers.
Tig
maybe i should of put a wink behind my post ;)
