New from Aerospce.
Billet 250 fuel pumps,
At 18PSI Race setting they flow between 290-305 GPH
At 10 PSI Street setting they flow at 220-240 GPH
The DB sound level is 40% lower than the 350 pumps at 10 PSI
Inlet should still be a -10 and outlet should still be the -08 or 1/2"
They draw 7 amps at 15 PSI, 5.5 amps at 10 PSI we still recommend a relay be used.
£320.00
Fuel pumps
Fuel pumps
- tn-Fuel-Pump-.jpg (9.7 KiB) Viewed 638 times
