Mixing tyres
Mixing tyres
Might be a silly question but why can't you have bias ply tyres on the front and radials on the back, I'm after fitting Mickey T front runners 28/7.5/15 on the front and Mickey T street radial 315/60/15 on the back, also is this illegal or MOT failure, I wont be doing many miles probably 20/25 miles to brooklands once a year maybe wheels day and krispy kreme once a month.
Hell Yeah!! I'm a Redneck
I may be a little thick, but I'm still not clear on this?
a. one tyre is of a different type of structure from another tyre on the same axle
b. a 3- or 4-wheeld vehicle fitted with single wheels, and
i. a cross-ply tyre or bias-belted tyre fitted on rear axle and radial-ply tyre is fitted on front axle, or
ii. a cross-ply tyre fitted on rear axle and a bias-belted tyre fitted on front axle.
Note: Any tyre ‘type’ mix between different axles is acceptable for vehicles that have
. 2 axle and ‘twin’ wheels on the rear axle
. 3 axles, one steering and one driving
Note: This does not apply to vehicles with an axle fitted with “super single” tyres having a road contact area at least 300 mm wide.
It is OK to have Bias front Radial rear as a tyre combination for the MOT.
The list you posted is the Reasons for Rejection (Failure) items for tyre structure combinations.
It does look a bit complicated but the only bit that would apply to a car is this:-
All the stuff listed below this applies to more oddball vehicles that would be tested in the MOT scheme such as an old 3 axle Bedford coach with both front axles steering. Much of this text was added when the Class 3,4 and 7 manual was combined with the Class 5 manual back in June .The coach example above would fall into Class 5 as a private passenger vehicle with 13 or more seats if it was not used as a PSV.
