Dart beater
Hi James, yeh Terry spoiled his by painting it
So far, new rear quarters and boot floor replaced plus a floor pan patch. Now pretty solid.
Has gas/air shocks front/back. Most of the work is going into the 360 motor which will have the following spec:
360 bored to 365ci, Hyperteuctial (or however!) pistons with 9.1 compression. Comp cams XE262 grind, rebuilt heads with correct springs/retainers etc, original 340 cast manifolds, edelbrock inlet, holley600 carb, 'leccy ignition. Rear is 8.3/4 with 3.23 gears
wheels are polished centrelines (formerly on Cliff Turners Dart)
with a modest tyre combo 195 x 65 x 14 and 225 x 60 x15
Thats it for now, I have got more pics but having trouble resizing!
