727 capacity
Rich
727 capacity
Post by Rich »
Does a figure of 19 pints seem right for an empty box?
Or to put it another way how much trans fluid should I put in an empty box and convertor with a B&M super cooler?
All answers in pints/litres/quarts/gallons/fluid ounces greatly apriciated..
19 pints (9.0 litres) is the standard 727 capacity.
Rich
Post by Rich »
I thank you.My old book must be right.I`ll just add abit on for the cooler.
The end of my stick is missing!!!
hey rich just dont overfill it, they have a tendancy to blow out the breather which is in the bellhsg it makes you think you have a pump seal leak
is that why i get a leak from the front of the tranny sometimes and not others, usual after a longer journey?
its possible sean thats your problem best bet is have the fluid between the hot marks full and low, when the box has done perhaps 10 miles running in neatral, they will also blow out the breather when the trans is badly worn
the level is about 2mm above the high mark when warm after say 10 mins of driving, how can you tell if your trany is worn- is there a way to tell with driving, its performance?
drop about a pint out off it and see how it goes i think you will be ok
