Easy way to remove plastic trim clips
You know, the type with a little peg that you have to knock out which is fine if you have access inside the panel to retrieve the peg.
At the risk of stating the bleedin obvious...
Drill a 2-3mm hole, screw in a woodscrew, pull peg out. Job done :thumbright:
Removing trim 02.jpg (105.92 KiB) Viewed 448 times
Removing trim 01.jpg (94.74 KiB) Viewed 448 times
steveo
Post by steveo »
clever idea 8-)
Can't remember how many of those little buggers I've lost! :oops:
I spent quite a while fishing one out of the bottom of my rear 1/4 so i thought... there must be a better way! :roll:
