Restoring gauge surround. Chrome paint?
My dash looked a right state.
The black had been painted in tar with a blunt stick by a drunk who'd then gargled with some dull aluminium paint and dribbled it over the top :?
I used thinners and a scotchbrite to remove the mess and i've sprayed the lot gloss black.
Is there any way of re-doing the chrome bits?
Are the aerosol 'chrome' sprays as crap as all the reviews i've read?
2nd pic is what it should look like...
Belve dash pic.jpg (142.42 KiB) Viewed 2546 times
Whats it made out of that you want to make look chrome??
ANTON
Post by ANTON »
Derek has used the silver paint pens from a craft shop with good results.
You could mask it up and spray it with a vibrate silver paint.
MrNorm
Post by MrNorm »
Options:
- paint it yourself with a 'chrome' aerosol. Will look decent, but not like exactly chrome. But cheap
- send it to be chromed (I'm assuming it's plastic?)
- send it to someone to do a pukka 'chrome' paintjob. It will look exactly like chrome (but I assume won't be cheap either...)
It's plastic. It originally had a chrome coating like you see on kids toys. Then it's overpainted with black. The wear had gone right through the black and the chrome.
It's to tricky to spray because of the lettering, etc :?
[quote="ANTON"]Derek has used the silver paint pens from a craft shop with good results.
quote]
I have seen this done and it looks pukka
The paint pens work quite well,although can be a bit "gloopy" if you go over what's been done too soon. best finished off with clear lacquer as the newness soon dulls.
It would be fiddly here, but you can use chrome tape too. Its really thin tape/foil (like small sellotape) which you stick on and then razor to size. Used on headrest trims and things... Its actually reflective (like chrome) as opposed to chrome paint which is , well, paint. i.e. not reflective.
Like I say, might be slightly more awkward for this, you have some fine detail there.
Roger
Post by Roger »
Hmmm, i too need a solution to this. Ive seen the Chrome paint and its really good, but the cost of buying what you need to use is way to much just to sort out my dash!
Gareth
Post by Gareth »
Try this tackle..........
http://alclad2.com/
Various different finishes available and formulated for use on plastic model kits.
DaveBishop
Post by DaveBishop »
Gareth I use alclad all the time. Have posted it on the message board as well but know one seemed to to take any notice. I have used it on the plastic back to the arm rests and they look great you can Bananarama! as well. as you said they do lots of different colours with the chrome you have to spay gloss Black undercoat.
2 x 1969 Dodge Darts
Jules
Post by Jules »
http://www.ebay.co.uk/itm/PILOT-SUPER-C ... 6d73875985
I used 2 sizes, the extra fine and medium.
Don't be too hastey to give extra coats too soon, as Steve says it goes abit gloopy, but done properly you get great results.
Of All The Senses, The Common One Is The Most Rare !!
MMA/750
I tried out a can of Simoniz chrome paint and it's not actually too bad!
It ain't chrome but it's a lot better than just silver paint. I masked and sprayed the surround then sprayed some paint ino the lid and brush painted the detail bits. Beiing a clumsy oaf it ain't perfect but i'm happy with it :)
I've also replaced the heater controls with a 'delete' plate, drilled for a couple of switches.
Dash restored.jpg (86.46 KiB) Viewed 2421 times
DaveBishop wrote:Gareth I use alclad all the time. Have posted it on the message board as well but know one seemed to to take any notice. I have used it on the plastic back to the arm rests and they look great you can Bananarama! as well. as you said they do lots of different colours with the chrome you have to spay gloss Black undercoat.
:thumbright: :thumbright: WIll try that :thumbright: :thumbright:
steer clear of the halford chrome paint
it iterally is no better than silver
but at least silver stays on
