hub rings for front wheels
LONGSHOT
Post by LONGSHOT »
just got a pair of front wheels for the dart and wondered if i have to use a spacer ring as they dont sit snug over the hub centre-is it dangerous without ?
cheers Dave
one day your life will flash before your eyes....
just make sure its worth watching.
dave" longshot" long
I my mind it depends on the wheel
mine don't centre due to late aussie ford spigot size but are thick hub alloy wheels
the nuts have a big fat alloy shank below the hex head which fits push tight into the long hole through the wheel
and the hex head has the radius to fit into a dish half way down the hole
so the wheel centres up great no issues no vibration
on the rear i have dust caps that fit in from the rear and take up the slack around the spigot....no good for accurate centering either
but same wheels with same long studs and nuts
not exactly a powerful car but ive had no issues....
i wouldn't be happy running steels like this with the small nuts with a radius into a seat on the wheel but little else they just hold the wheel to the hub they don't do much else
or wheels that have flat nuts and hardened washers that fit into a circular indent around the hole on the wheel
as neither give the wheel stud holes support along the length of the stud like my current set up does
http://www.mistertee.co.uk/6.html
my nuts are like flat top SST or open end sst mag
not
hex open bulge ET
or any bulge type
i.e as it says on the top of that page
Alloy wheel nuts are usually the sleeve type, with a shank which fits inside the wheel hole to locate the wheel.
which is why i'm not that worried
LONGSHOT
rings
Post by LONGSHOT »
cheers for a most comprehensive answer :thumbright:
i should be ok then with what i have already
8-)
