Line loc info please
Adrian Worman
Post by Adrian Worman »
Maybe want to fit one on my challenger but what exactly is involved in the install? I may have most of this stuff at work :read2:
Jesus built my hot rod
72 Challenger
65 Barracuda
andyrob
Post by andyrob »
Adrian, Line-o-locks work in 2 different ways you can either plumb them to lock the front brakes on (good) or switch the rear brakes off (bad- cos if you forget to switch it off you drive around on front brakes only).
You can simply put one in line on front brake circuit, with an elecccy one you simply install it into the front brake as it comes out of the master cyclinder or if you dont like fancy electric things you route front brake pipe into car near you & have a manual valve which you physically turn on or off
simple as that
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
I have a 2nd hand one off the Barracuda if you want...
Ade on a manual car you need it to lock your brakes on- you don't have enough feet otherwise! ;)
shovelheadrob
Post by shovelheadrob »
If you don't have one on an auto car & you left foot brake you can cook your rear brakes or at the very least wear them out quicker!
Adrian Worman
Ta for the info Andy ;)
I'll be in touch Pete :thumbright:
........... exactly why I don't wanna just stab the brake pedal once I got the tyres spinning Rob, it'll Bananarama! em in no time eh?
............. ain't you heard of fancy footwork Paul? :D
72 Challenger
65 Barracuda
It don't work; I had a Line Lock when the Sox Barracuda was a 4 speed - it is essential.....
