Rust protection, what to use ?
Johnny Dart
Post by Johnny Dart »
I sure this has been asked before,but I know products change and new ones become available.
I don't want to use my rust free fresh import,on our roads until I've filled it up with waxoil/dinitrol/????
What is the current best jollop for treating ?
GJUK
Post by GJUK »
I've used waxoil before.
Krust on exposed metal.
Johnny Dart
GJUK wrote:I've used waxoil before.
I'm thinking what to use inside the doors and sill and box sections,but also on exposed areas like floors arches ect.
Waxoil is my first thought , but wondered if any thing was considered better ?
Adrian Worman
Post by Adrian Worman »
When you spray inside doors, rear qtrs etc, make sure you don't block factory drain holes ;)
Jesus built my hot rod
72 Challenger
65 Barracuda
I like the Dinitrol range of products. Not saying they are any better. But they do just the right product for every aspect of the job.
vipergts
Post by vipergts »
This is the Daddy
http://www.bilthamber.com/cavity-waxes
All the big boys use it now
68 Charger 440R/T
66 Sting Ray 427
67 Mustang 390GT Man
68 Corvette Stingray Rdstr
08 FGT
A dry garage;best prevention of all!
A dry warm garage and a car with a plastic body is even better. :lol:
GJUK
Post by GJUK »
Adrian Worman wrote:When you spray inside doors, rear qtrs etc, make sure you don't block factory drain holes ;)
That can be hard to do, just use it in the dry also. Never in the wet/salt.
Jon
V8 Sam
Post by V8 Sam »
i also second waxoil
GJUK
Post by GJUK »
V8 Sam wrote:i also second waxoil
Plan well ahead when using this stuff, takes ages to warm up in water. mix with a bit of white spirit also to thin.
Johnny Dart
vipergts wrote:This is the Daddy
I must say that this stuff looks quite good !
Just seen the gritter truck go past, Hi hate all that salt :cry:
Ive recoated the factory undercoat on my Polara using waxoil spraycans. Warm them up in warm water for 5 mins or so and away you go. Six cans did my car and Ive just used it to do the inside of the new repair sections on the Fury. DONT get it from Halfords as they charge £8 a can. Can be had for half that!! Oh, and if you dont use a whole can, throw the spray nozzles in some thinners to keep them clean for next time.
Cheers Steve :thumbright:
Dave wrote:A dry warm garage and a car with a plastic body is even better. :lol:
And the un seen tin worm gobbling up the inner frame.
I dont have as bad a rust issue as alot of you might have so it is interesting to see what people use :thumbright:
Johnny Dart
My car came from the Nevada valleys and later Arizona, so the weather has been kind to it.I want to keep it that way.
Unfortunately we keep throwing salt all over the roads, I noticed the local council gritter trucks out a couple of nights ago.
I must get it filled up with something before I get it on the road.
