Rear tyre / leaf spring clearance
dustymopar
Post by dustymopar »
I have read that 1/2" clearance between the rear tyre inner sidewall and spring is a safe minimum......
Would anyone agree or disagree with this?
TIA :thumbright:
GJUK
Post by GJUK »
interested in the responses :)
Adrian Worman
Post by Adrian Worman »
I've always worked on that theory Dusty.
The spring clearance is fine at that but carefully check the tyre against the inner and outer wheelhouse.
If I can't get a finger between the sidewall and wheelhouse I consider it too tight.
It's not that the tyre clearance is an issue, tyre growth, sidewall flex and under inflation won't usually exceed that amount but if you get debris off the road between the two it will likely damage the tyre ;)
Jesus built my hot rod
72 Challenger
65 Barracuda
I would agree that a half inch is a MINIMUM for a 50 or 60 series tyre. I have seen cars with as little as a quarter inch but high sidewall tyres WILL flex from side to side.
A really BIG sidewall tyre I would say more like an inch clearance.
I think TYPE of tyre may also have a bearing.
The big old M/T Crossplys I have on the Coronet flex an awful amount in corners, I bet Radials are far more stable from a sidewall perspective.
dustymopar
Thanks everyone ;)
TW71
Post by TW71 »
If you intend ever to run slicks beware of tight clearances, I have run into problems where the temperature increase over the day has resulted in the tyre wall expanding to the point of rubbing the springs or wheel arch :shock:
