Truck tyre pressures
Just out of interest. What pressures do you run in your D100's / Rams etc ?
40 psi seems about right in mine. Drop to 30 in winter conditions ( with a few bags of sand on the bed !)
Cheers :thumbright:
My Durango should be at 33 psi but seems to work better at 40psi....weighs 5000 lbs so that is a consideration........
Pete wrote:My Durango should be at 33 psi but seems to work better at 40psi....weighs 5000 lbs so that is a consideration........
Thanks Pete. Don't know what the truck weighs , but is the military heavy duty version. Any more than 40psi rattles your teeth. Any less and its a C body ( sorry !)
Tyre wear indicates I'm right , but interested what others run. Seems the yanks run up to 70 psi to get better fuel economy :shock:
I have got the military pressures in the door shut. 40 front 70 rear.
Daren't try it as I don't fancy dentures just yet :lol:
When I bought the Durango it was at 65psi :shock: :shock:
The tyres are not rated that high..........
I have just put new tyres on the back and it squeals on roundabouts at speed so it may need some adjustment...........
Pete wrote:When I bought the Durango it was at 65psi :shock: :shock:
What was your choice of tyre Pete. ?
I think they were round ones......
Pete wrote:I think they were round ones......
:lol:
And here's me trying to be serious for a change !!!!
Well if they're squealing round corners ...................SLOW DOWN !
I keep mine around 30, any higher it'd shake itself to bits! :lol:
shovelheadrob
Post by shovelheadrob »
What does it say on the tyre? xxxx lbs/kg at xx psi, should be more than your axle weights, then drop the pressure down accordingly. Remember that the manufacturers recommendations are for the tyres that were fitted from the factory. May not have been radials & probably a different size.
Just looked out of the window and they are Goodyear Wranglers....
Mossy68 wrote:Well if they're squealing round corners ...................SLOW DOWN !
That noise is normally his passengers.... :lol:
We had a deadline, and I have grown up a bit since then ;)
Says the man building an Altered !!! :shock:
Never underestimate a Supercharged Mercedes and a man late for his dinner - it's a long story.............
bratfink
Post by bratfink »
I run mine at 60 front and 65 rear.
Mine are E load rated and are supposed to be run at high pressure. Not sure on the 1500's since mine is a 2500.
