68 Charger Front Sway Bar bent
Glen63
Post by Glen63 »
Been working on the Charger today and have noticed the front sway bar on passenger side is bent inwards by about 2 inches, causing the link arm to rub on the torsion bar.
All the rubbers could do with replacing as well, but it is a factory fitted swaybar.
Question do I see if the local blacksmiths can get it back in line, buy a new standard one from Rockautos or go for a upgrade ?
Adrian G
1968 Charger 318ci V8
1977 Dodge RV Camper 440ci V8
1978 Jaguar XJS 5.3 V12
1984 Mercedes 280 SL
1998 Jeep Cherokee 4.0
1999 BMW 530i
Got a pic ? Doesnt sound that big a deal unless I am missing something ?
New rubbers/mounts and a blacksmiths tweak you are done. (was on mine anyway)
Re: 68 Charger Front Sway Bar bent
Glen63 wrote:Been working on the Charger today and have noticed the front sway bar on passenger side is bent inwards by about 2 inches, causing the link arm to rub on the torsion bar.
i have a good used one,
Glen63
Post by Glen63 »
Yes my first thought was just to get the local blacksmith to adjust back the couple of inches it is out.
But I presume these are tempered steel to give them some springiness , which could be lost if he heats it to bend it ?
Plus he says he is busy until after Christmas !! Have spoken to the guys at my local Land Rover place and they are happy to have a look at it, would be best to do it with a bench press, cold I think.
Adrian G
1999 BMW 530i
Speak to mr.Cannonball. He'll have dozens. You can get it shotblasted, powder coated, new set of mount bolts/rubber. Like new...
