1/8th - 1/4 mile Question
BUDGIE
Post by BUDGIE »
Odd question but if a car is running a 6 sec @ 112 1/8th what time will it run in the quarter? ........there again it's probably runnin 5.10 gears, but I'd fit a 4.10 gear if that where the case. .......... :scratch:
As you have rightly indicated you cannot really tell as it will run right out of revs.
What you really need is the rough BHP it makes and its weight; gives you much more to work with.....you can then substitute Tyre Heights and gear choices in the programmes that predict ET's and MPH..........
9.50 @138 using an online 1/8 to 1/4 mile calculator.
Les Szabo
Post by Les Szabo »
Just elaborate on what Blue said.....an optimum chassied car weighing 3000lbs all in>32" tall slicks>4.56 gears>690hp should run.....
60 Foot E.T. : 1.32
1/8 Mile E.T. : 6.00
1/8 Mile Trap Speed : 113.37
1/4 Mile E.T. : 9.50
1/4 Mile Trap Speed : 141
1/4 Mile Trap RPM : 6,757
Re: 1/8th - 1/4 mile Question
BUDGIE wrote:Odd question but if a car is running a 6 sec @ 112 1/8th what time will it run in the quarter? ........there again it's probably runnin 5.10 gears, but I'd fit a 4.10 gear if that where the case. .......... :scratch:
my chally was a 1/8 mile car 5,38 gears it ran usa 5.52 at 126 best but most times 5,56 125 at 7,200 rpm,s so i took it shakey with the 5,38,s ran it up to 7,200 rpm,s and Bananarama! me 1/8 et 5.56 125 mint the bloke was not tellin porkies, he was a smashin guy by the way, anyway swapped out to 4.56 = 1/8 5.56-58,s at 124=125 quarter 8,91 151 well happy it ran a high 8 every meet no matter what but never bettered that 8.91 from its first time out, thats when i first met ya budge you were a tease even then,,, ;) :lol: :lol: :lol: :lol:
Les Szabo wrote:Just elaborate on what Blue said.....an optimum chassied car weighing 3000lbs all in>32" tall slicks>4.56 gears>690hp should run.....
60 Foot E.T. : 1.32
would have to be perfect for that many cars get good mph but lack in the trouser dept et,,,
Les Szabo
Post by Les Szabo »
60 Foot E.T. : 1.32
Absolutley Dunc :lol: ....we all know 1 car that does as good and even better on 60ft's sometimes than the Wallace calc says it should, and its on springs ;)
BUDGIE
Post by BUDGIE »
Thanks chaps .......... :thumbright:
Les Szabo wrote:
60 Foot E.T. : 1.32
Tiggs chally ??? Dave Bills superbird ???
BUDGIE
Post by BUDGIE »
Dunc, was it runnin the Hemi or the wedge :?
Les Szabo
Post by Les Szabo »
Cannonball wrote:
Les Szabo wrote:
Cannonball wrote: would have to be perfect for that many cars get good mph but lack in the trouser dept et,,,
Don't know Tigs/Dave's 60fts....no its Mick, people don't seem to think about Micks Dart much but it gets my Vote :thumbright:
it was the wedge with indy sr,s fitted mild cam was a very mild build but ran good no,s and zero maintenance,
BUDGIE
Post by BUDGIE »
So if I fit 4.50s with 700hp and a lighter car I should do the same numbers right :?
Les Szabo
Post by Les Szabo »
2800lbs at the line, 32" tyre, 700hp, 4.50 gear
60 Foot E.T. : 1.29
1/8 Mile E.T. : 5.83
1/8 Mile Trap Speed : 116.50
1/4 Mile E.T. : 9.25
1/4 Mile Trap Speed : 145
1/4 Mile Trap RPM : 6853+slip
These are optimum figures not an absolute.
