Posts: 2338 Joined: Thu Mar 21, 13 5:05 pm
Post
by cadboy » Thu Jan 08, 15 7:46 am
Has anyone ever seen or come across a car with 3 wheels with standard Right Hand thread wheel nuts and one wheel with left hand thread nuts!!!!!!!!!
Strange but I found that one wheel on my car has this, and I managed to sheer one off when trying to undo it.
I have steel wheels with Acorn standard wheel nuts.
shovelheadrob
Posts: 959 Joined: Tue Sep 18, 12 10:27 am
Post
by shovelheadrob » Thu Jan 08, 15 8:03 am
Hi Ali, a lot of Mopars came with l/h thread on one side of the car, I'd guess that one wheel set has been changed already. Just change the remaining wheel studs it will make life easier in the future. .
Posts: 5251 Joined: Mon Dec 12, 05 11:40 am
Post
by Charger » Thu Jan 08, 15 8:12 am
as said, originally, up to the early 70’s I think, they had lh thread stud’s/nuts on the lh side of the car, rh thread stud’s/nuts on the rh side of the car, my Charger is still like this
if you need any supplies nuts related, try Tim at ‘Raceways of Donnington’ 01283 517935
http://www.raceways.co.uk/Wheel_Nuts_an ... sories.htm
383 | 4bbl | 727 column | PAS | PAB | buckets/buddy - check out my photos
HERE
1970 Dodge Charger Registry -
https://www.1970chargerregistry.com/
Posts: 7141 Joined: Fri Jul 23, 10 4:01 pm
Post
by Dave81 » Thu Jan 08, 15 1:30 pm
shovelheadrob wrote: Hi Ali, a lot of Mopars came with l/h thread on one side of the car, I'd guess that one wheel set has been changed already. Just change the remaining wheel studs it will make life easier in the future. .
Mine were already RHT but Jim had one shear off when he was doing the brake lines.....
Luckily id already got replacements.
Mine are Doorman (Rockauto). They are cheap to buy, so worth doing IMO!
Posts: 4084 Joined: Tue Oct 13, 09 10:02 pm
Post
by drewcrane » Thu Jan 08, 15 2:26 pm
Most yanks replace all the studs with rh threads, and i too had a car with 4 lh and one rh, and yes I boogered it up, and made a nice mess when I was done, I fought that thing for the whole day.
Get the doormans and change em out
Post
by cadboy » Thu Jan 08, 15 5:08 pm
So it was standard on the Mopars (well I never knew that)
It is the front wheel, driver side, so left side, the back on the same side has RH nuts.
Okay time to get the only one changed to RH, same as the others.
Cheers guys
Jeff
Posts: 7972 Joined: Sun Apr 18, 04 11:09 pm
Post
by Jeff » Thu Jan 08, 15 5:18 pm
Mu Fury was the same.... I painted info on the wheel under the hubcaps. Cos there are a lot of idiots out there in the Wheel and tire world.
Took it in for a safety, and they informed me one of my drums was warped. You can guess why!
Posts: 22170 Joined: Sun Apr 18, 04 10:49 pm
Post
by Pete » Thu Jan 08, 15 6:11 pm
pre-'70 the LHS (Drivers side) front and rear had LH wheel nuts..........
Posts: 6747 Joined: Fri Jul 14, 06 8:01 pm
Post
by mopar_mark » Thu Jan 08, 15 6:36 pm
drewcrane wrote: i too had a car with 4 lh and one rh
I bet those 5 wheelers are rare these days
Posts: 7679 Joined: Wed Jun 27, 12 6:57 pm
Post
by Mossy68 » Thu Jan 08, 15 6:46 pm
Posts: 14523 Joined: Sun Apr 18, 04 11:29 pm
Post
by Blue » Thu Jan 08, 15 6:58 pm
Pre '73 on A bodies, very common to find a broken stud on a car that hasn't had the original LH studs swapped out as they are only 7/16".
Post
by Mossy68 » Thu Jan 08, 15 7:44 pm
Is it true that this system is still used on HGV's ?
Post
by Blue » Thu Jan 08, 15 8:47 pm
It's not common but yes, I've come across it on the heavy stuff and vans as well, can't remember which ones though....
Posts: 9592 Joined: Thu Feb 24, 05 10:31 am
Post
by Dave999 » Fri Jan 09, 15 12:05 pm
sombody swapped in an updated half shaft or started on the left rear broke it updated it and left the front alone
Post
by drewcrane » Fri Jan 09, 15 12:40 pm
Dave999 wrote: sombody swapped in an updated half shaft or started on the left rear broke it updated it and left the front alone
They must think others that will work on the car in the future , will have x ray( vision(and flying cars), and see that front is different
