Wrapping manifolds?
Wrapping manifolds?
Thinking about wrapping my manifolds on my Chargers 383 to try and stop heat build up boiling off my fuel in traffic and stopping her restarting after a long run, but have heard horror stories of manifolds cracking, gaskets melting and the wrap catching fire!! Would love to hear any advise you all may have out there.
(There aftermarket tube headers not the old cast ones)
Thanks Steve.
Thanks Steve.
- Dave-R
Your car may well be "running" but ignition timing and carb tuning will make it run as it should. The pay off being it will also run stronger, smell better, and run a lot cooler under the hood.
If needed you can also put an insulating spacer under the carb and block off the heat cross-over passage through the bottom of the intake.
- octanejunkie
- Rogue Trooper
My headers have been wrapped for nearly 10 years, its doesn't do big miles granted but when its out for a run it gets Hooned and the wrap is still on.
Still gets Bananarama! hot mind but it still must be a lot cooler then uncoated headers I'm sure.
I'll shall be trying Zerotec on my next Engine updgrade
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
1934 Coupe
1954 F100
Your Mum Says Hi.
- autofetish
I would listen to the above about timing etc
These cars ran in California!!!!
Wrapping steel headers there are going to rust Fact
Also if you had a fuel leak there a massive sponge and Fire hazard waiting to happen
If you don't do them tight they will tea bag and look crap
The trick is to do then wet buy soaking the wrap for a few hours in bucket of water. Then wrap them wet.
When dry they will shrink.
Also wire then at close intervals
They will use double the wrap you thought you needed and take 4x as long
Also if new build trial fit first as I had to drink a few Stella and knock my about abit starter motor / Power steering
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 567b84.jpg" border="0" alt=" photo IMG_1148_zps77567b84.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... f9d16c.jpg" border="0" alt=" photo IMG_1150_zps08f9d16c.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ecb85e.jpg" border="0" alt=" photo IMG_1181_zpsb7ecb85e.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... c829b8.jpg" border="0" alt=" photo IMG_1178_zps44c829b8.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 0ad660.jpg" border="0" alt=" photo IMG_1251_zps290ad660.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... d8a63b.jpg" border="0" alt=" photo IMG_1255_zps64d8a63b.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 82884f.jpg" border="0" alt=" photo IMG_1258_zps1f82884f.jpg"></a>
I agree ceramic coating is the best, if it is good enough for McLaren and Lamborghini, then it should be good enough for us. Zircotec is the company to go and they are only in Oxford.
I had one of my other cars cast iron manifolds done by them and it sure does work. They can even do the exhaust pipes, so cuts down on heat transfer under the floors, but it is expensive enough just for the manifolds.
www.zircotec.com/page/our_exhaust_coatings/60
Adrian G
1968 Charger 318ci V8
1977 Dodge RV Camper 440ci V8
1978 Jaguar XJS 5.3 V12
1984 Mercedes 280 SL
1998 Jeep Cherokee 4.0
1999 BMW 530i
1999 BMW 530i
- Rogue Trooper
Fantastic wire job on those headers Autofetish wow!!!
As for headers cracking early on after wrapping, not all headers are built equal!!
Cheap headers are made with thin walled tubes to start with so you get what you pay for and wrapping them will end there life early!!!
1934 Coupe
1954 F100
Your Mum Says Hi.
1934 Coupe
1954 F100
Your Mum Says Hi.
- mopar_mark
I used Zircotec for my headers & turbo exhaust, got a real good discount through Andy F, but cost was almost as much as the headers ...
I did go for the better thermal rating, which pushed the price up. But guaranteed to reduce temps by 20%
Very friendly company, easy to talk to, showed me round there premises too. Turn round was good & as per their quote.
I would use again
I would use again
