steering Column
CRAIG
steering Column
Post by CRAIG »
Hello
you can pull my steering wheel backwards and forwards about a cm on my 69charger. Not sure if the top bearing is the right one.
Also When you remove the steering wheel and fist part of the cover and bearing you can move the shaft in and out. Is this normal?
Any ideas?
1969 Dodge Charger
1972 Chrysler Hardtop
on mine
the wheel comes off the can
the can needs a specific puller
there is the indicator gubbins and some other thing, possibly some kind of retainer, or maybe thats the base plate to which the indicator cam bolts.....
this is all from memory but it makes sense when you see it
and a circlip. this is key....
the circlip can come out of its grove on the steering shaft which allows the shaft to move up and down through the circlip and the top bearing.
OR (from memory remeber)
the circlip holds the top bearing in to its housing and it is moving up and down with the steering shaft.. one or the other can't remember which
either way the circllip and retainer are key to having a column that stays put. and if the column is in the wrong position you can't see the groove where the circlip should go.
little danger if it moves up and down cos it can't move up enough to dislocate the coupler at the bottom.
but it can impact horn and engagemnet with the cancellor for you blinkers
and may add extra stresses that will break the blinker clicking cam
i dscoevred why mine moved when swapping out the blinker switch due to busted cam
It moves because the coupler down the bottom end at the top of the steering box allows play to cover off flex in the front of the chassis.
Mine is Aussie. i'm 90% sure it will be every similar..... may not be
CRAIG
Post by CRAIG »
Thanks, Dave, I have the circlip, but I have seen a photo of a retainer plate that screws in with about 3 screws. I don't have a retainer. Would that cause issues?
1969 Dodge Charger
Is this not the safety feature when you have a crash
I have never understood it blue new everything about it if I remeber
CRAIG
Post by CRAIG »
I will try and post some pics later of my set up. I just want to make sure I have all the right parts.
1969 Dodge Charger
Think its advisable to have it all correct.
you may or may not have anything missing. might all just be in the wrong order
i seem to rember a plate with screws holding it down
but again mine could be different
There should be no in and out movement, there's a circlip either side of the bearing to stop that. If someone has removed the steering wheel by whacking the centre of the column, that usually unseats one or other circlip.
<a href="http://s73.photobucket.com/user/autofet ... x.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 5q1mhx.jpg" border="0" alt=" photo 397147B6-5931-4029-AAF5-180F3B0A7654_zpsez5q1mhx.jpg"></a>
CRAIG
Post by CRAIG »
Thanks for the diagram, the bottom circlip was missing. That has solved the back and forward movement. but there is a bit of side to side on the shaft. I don't have the support 14-96-8 on mine. is that the problem?
1969 Dodge Charger
You playing games ? I have gone blind looking :lol:
CRAIG
Post by CRAIG »
Sorry, im an idiot, its 19-46-55 :oops:
1969 Dodge Charger
That's looks to be the problem :thumbright:
Wanted add
wonder why such an important bracket would be missing?? :read2: :read2:
CRAIG
Post by CRAIG »
My column is made up from parts, that looks to be the only but missing.
Does anyone have a spare?
Or could I get away with making a hard rubber bushing to slot in the tube
1969 Dodge Charger
CRAIG
Post by CRAIG »
is part 19-46-8 housing, held in place with any screws pins etc. As when the columns all assembled with the clip either side of the top bearing the housing is a bit loose. is this normal?
1969 Dodge Charger
