OUTDOOR CAR COVER NEEDED ASAP!!
danny_duke01
Post by danny_duke01 »
Hi all,
My Fury is being delivered back to my home on Thurs afternoon and desperately need a car cover by then. It is just a freshly painted body with no glass fitted etc,so it's very essential!!
Any recommendations please??
1978 Fury
Length = 18ft 2in
Height = 4ft 6in
Width = 6ft 5in
Thanks in advance!! :thumbright:
1978 Plymouth Fury,4-door sedan B-body,400 cu in (6.6L) Big-Block 4 barrel V8 'High Performance'
(numbers matching with Police special handling package)
MMA / 911
GJUK
Post by GJUK »
Build a shed or similar?
Outside = not good.
danny_duke01
GJUK wrote:Build a shed or similar?
Outside = not good.
Looking to move soon and car will be under cover for good,but need one now for a few months.
MMA / 911
GJUK
Post by GJUK »
You might be best lashing up some structure then, plastic sheeting to keep the rain out and the wind will keep it dry.
do not sheet that fresh painted body shell it will hurt it tape the windows up but leave the body open wait till you got covered storage,
have you got room for something like this ...
http://www.ebay.co.uk/itm/Portable-Gara ... 0709281698
Can you not hire a lock up or temporary storage in the interim?
A flapping car cover on new paint does not sound like a good idea to me.......
TW71
Post by TW71 »
You will get dampness under the cover, when it get's warm it will effect the new paint, could go milky / patchy.
Also wind make the cover rub on that fresh paint.
Whatever make sure there is air around it, like the portable garage type. ;)
If its for security or to keep it at a lower profile I understand thats important too.
Carl
Post by Carl »
Also paint can micro blister with the moisture under a cover. I use a portable garage.
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
Guy
Post by Guy »
I agree with every one else, Dont cover it it will wreck your fresh paint
danny_duke01
Thanks for all the advice guys...just for now i've got a cover for the roof & windows only,not a full car cover. Least it will keep the inside dry which is my main concern 'til i fit the glass back in. :thumbright:
MMA / 911
Yeti
Car cover wanted
Post by Yeti »
Look up Carcoon. I will be getting one for mine when I get it. Not cheap but you drive in and seal it afterwards, it then blows air constantly around the car to dry it and keep the car spotless. If you get the Veloce version, is inside only but look at the specs wow. All the best. Vinnie
Bryan
Post by Bryan »
Ive got a cover you can have. I dont use it anymore as mine is garages now.
£30 plus postage.
Re: Car cover wanted
Yeti wrote:Look up Carcoon. I will be getting one for mine when I get it. Not cheap but you drive in and seal it afterwards, it then blows air constantly around the car to dry it and keep the car spotless. If you get the Veloce version, is inside only but look at the specs wow. All the best. Vinnie
That's what I have,very rare secondhand,found mine on ebay for £600 less than new. Previous owner kept a Cadillac in it.
