Which ball joint splitter to use
Coupe66
Post by Coupe66 »
Hi all,
I need to replace the ball joints inner & outer on both track rods on a 68 Charger. Does anyone know what 'size' pickle fork or ball joint separator I need, I've looked on ebay and there are a number different sizes.
Cheers - Mike
Rebel
Post by Rebel »
I use an 8 inch pickle fork
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
Coupe66
Post by Coupe66 »
Thanks' Rebel,
I'll get straight onto ebay and see what offerings they have.
Cheers - Mike
I have only ever used a universal one - as long as it clears the taper on the ball joint. Cheap and cheerful. I tried a "screw in" type once but that did not work for me.
undo nut slightly and hit the end of the crosslink or balljoint arm 3 times with a BFH. (big hammer)
if that doesn't work
relax have a cup o tea.
Then resume the prone position
and do it again.
pickle fork is effective but it knacks the seals.
the original seals are often better than the rubbery flubbery or urethane they put on new joints.
if the seals are ripped by all means fork away
Where there's room I use 2 hammers,slacken nut and clout each side of the taper at the same time.
Rebel
Post by Rebel »
I have a selection of them, screw type, scissor action and pickle fork. I've seen the hitting of the arm with a BFH on TV and YouTube countless times, it never works for me though, it's not like you can do it the wrong way is it. Something satisfying about belting a pickle fork though :D
'68 Dodge Charger
‘75 Ford Ranchero
MrNorm
Post by MrNorm »
Rebel wrote:I've seen the hitting of the arm with a BFH on TV and YouTube countless times, it never works for me though, it's not like you can do it the wrong way is it.
What he said^
It does work. BFH when done correctly will just make the joint jump off.
I have resorted to pickles when dont care if survives.
Yea BFH,can take a few whacks or sometimes just one or two.
Bozwell
Post by Bozwell »
get one of these splitters.
best ball joint splitter iv'e ever used. fully adjustable and dont go with a bang when the joint lets go.
hitting with a hammer does work but it'll leave dents.
