My '69 Charger, its resting
- sidewaysjas
My Charger is stored in a container at the moment, but couldn't resist taking a look today and firing it up!
Jas
Jas
- incontainer.20.jpg (48.47 KiB) Viewed 3453 times
'wouldn't change if I could'
- sidewaysjas
charger
Its amazing just how small a 20ft container is when theres a Charger in it.
Jas
Jas
- sidewaysjas
charger
Unfortunately I can't drive it at the mo' as it seems to have broken the crankshaft rear seal. When its running it deposits large amounts of oil on the floor!
Jas
Jas
Re: charger
Welcome to my world.sidewaysjas wrote:Unfortunately I can't drive it at the mo' as it seems to have broken the crankshaft rear seal. When its running it deposits large amounts of oil on the floor!
Jas
We had 4 attempts to get it to seal on the race car.
Mr Billladeau has the recipe for this fix.
(slightly off topic) - I love the stance on Dereks car.
Thinking I took mine too low at the back now - I have a very level stance but that very subtle rake is about right I think. While the axle is out I'm gonna knock it up an inch - Car looks great Derek.
Jas - Are you posting from inside the crate ? Cant see how you would have got out...
Containers
Quiz question please - are there any condensation issues using these containers as storage? I have potential use of one but heard conflicting reports about condensation when doors sealed for long periods.
Thanks
David
Thanks
David
- latil
I certainly wouldn't use a container to store my car unless some form of ventilation was provided top and bottom,they sweat really badly after a cold night and then the sun coming out,literally water running down the walls.
yes b bodies are a tight fit in a container !Pete wrote:Blimey, that's a tight fit
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
Re: charger
If you have power there id be be putting a dehumidifier in the container, as even though it may not leak theres always condensation in these cold temps, or open the doors once a week.sidewaysjas wrote:Its amazing just how small a 20ft container is when theres a Charger in it.
Jas
Otherwise you will have mould which always starts on the seatbelts for some reason and probably worse under the car what you cant see
Ive got a 40 x 50 steel shed and I get a couple of pints of water PER day out of the dehumidifer at this time of year and i stopped putting good cars in the containers I have
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
- sidewaysjas
container
Have had the container for a couple of years now. It has two small vents built into it on each side. Only ever had very slight condensation, it does get very warm in the summer though and makes the fuel evaporate, never enter it with anyone who smokes!
At the time it was my only option as a lot cheaper than building a garage.
Jas
Jas
