Seatbelts ('72 Demon): Can someone educate an idiot?
Super Sloth
Post by Super Sloth »
I give up. I've been thinking on this for 48 hours and I can't work it out. So here's the first silly question from me... Can someone please explain to me how these seatbelts work?
The male buckle with the retracting mechanism attached to either side of the benchseat base (a) will connect and release quite happily with the female recievers in the middle of the bench (b) but I can't work out what to do with the shoulder belt that clips into the roof brackets(c)?
Thanks in advance,
Jon.
A:
B:
C:
-Jon.
From what I can remember, the lap belt normally has a metal button that the shoulder belt hooks onto.
Dart Vader
Post by Dart Vader »
check under the bench seat for another couple of female buckles
if you have the mounting point bug no buckles then they've been lost
on my dart I have two female for the driver and two for the passenger
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Super Sloth
Hi Blue / Dart,
Thank you for replying.
I can't find anything that would resemble either an extra hook or a button on either end of the lap belt on either side of the car?
There are no additional fittings on the seat either?
-Jon.
Blue wrote:From what I can remember, the lap belt normally has a metal button that the shoulder belt hooks onto.
Yep has it on my 72.
Lap belt realistically with a hook on diagonal..............guess what I leave hooked to the roof........ :help:
In all honesty, not sure it would help much in a big emergency........ :shock:
Super Sloth wrote:Hi Blue / Dart,
Taking a closer look a at those lap belts, they don't look like original Mopar parts to me, I think someone has replaced the originals for some reason.
Super Sloth
Blue wrote: Taking a closer look a at those lap belts, they don't look like original Mopar parts to me, I think someone has replaced the originals for some reason.
I think you've cracked it, Blue.
I've just been having a nose on ebay US (I guess that's going to be my night time entertainment from now on!) and I've found a set of belts advertised for a '72 duster with totally different lap belts.
http://www.ebay.com/itm/mopar-a-body-72 ... 2164701730
These clearly show a little mushroom on the male half of the clasp as you described which would match up with what I have bolted into the roof of the car.
Additionally, the female front clasps in our car are a different style to those fitted in the rear. However, the female clasps in the advert above match the style of the units fitted to the rear of our demon exactly?
So, as you say, I guess the belts in the roof are right and the lap belts need to be swapped out.
At least I know it's not me being stupid now! :D
-Jon.
GJUK
Post by GJUK »
... Time for a roll cage and some harnesses then... :D
Super Sloth
If I rock up to the mopar nats with a roll cage and a bone stock 318 no one will be able to catch their breath long enough to talk to me for laughing. ;)
-Jon.
GJUK
Post by GJUK »
Got to start somewhere, I will shake your hand.
Every car needs a roll cage.
Put a roll cage in that beautiful car and you might get lynched :lol:
I was given a set of belts for my car from a Cuda: took me ages to work the, out. I felt pretty stupid but sorted it eventually.
skippy
Post by skippy »
On my Duster with bench seat I have three per side and they all fix to the same point and go through the seat base.
1970 Plymouth Duster
2000 Dodge Durango SLT
1974 Mk1 Escort RS2000
1981 Chevy G30 motorhome
Plus whatever else is kicking around on the drive :)
