Temp gauge woes
aussie pete
Temp gauge woes
Post by aussie pete »
On the charger (vh 770), that I am working on (yes its taken longer than planned !!!!) the temp gauge goes all the way over to the right (hot) as soon as the ignition is turned on.
Tested voltage at the sender.....12v
Replaced sender in manifold.....no change
Tried a spare gauge....no change
Previous posts state that the gauges run at 5v and needs a voltage regulator/limiter, however the factory workshop manual mentions nothing of this and spare parts that I have lying around show no evidence of it either,......any suggestions?
no the 5 volt malarkey is a US thing
temp sender sits in head on a hemi 6 car
I always presumed 12 volts comes out of the gauge
and the senders resistance dictates where the needle sits
I think you have a short in your sender wire
no resistance = 12 volts through the gauge and full swing to HOT.
OR
it works the other way and you have a problem with one of the 2 bulkhead connectors. i.e full resistance = HOT
think the sender is through the one which also has the wiper power through it
aussie pete
Ok I have now sorted it, I was convinced that it needed a voltage regulator, thanks Dave for steering me away from that idea.Further investigation and it became apparent that the temp gauge casing was'nt earthed.Wonse it was earthed the temp gauge came alive,.
ahhh
dash out
indicators don't work
guges don't work
driving lights work
windscreen wipers don't work if the switch isn't earthed
its a bit of a mine field
the only things that always seem to work are the horn and the ciggy lighter feed
hence the sparks :)
