A body PCD
skippy
A body PCD
Post by skippy »
I'm having a senior moment, what year did the PCD change on the A bodies? Would a 71 Dart be 4 or 4.5 PCD?
1970 Plymouth Duster
2000 Dodge Durango SLT
1974 Mk1 Escort RS2000
1981 Chevy G30 motorhome
Plus whatever else is kicking around on the drive :)
Should be 4", A bodies went 4.5" in '73.
4 x 7/16"
Change over was Mid -'72 from memory, the same time as large ball joint.
skippy
Post by skippy »
Thought it was, bugger !!!!!!!!!!!!
DaveBishop
Post by DaveBishop »
73 A body drum brakes were still 4inch
2 x 1969 Dodge Darts
All slant 6 A bodies up to 76 were SBP.
Factory V8s 74+ were all BBP.
73 was the change over year. Most V8s had the upgrade, but I believe some of the early 73 cars had a mix.
DaveBishop
Dave the problem with that is that Belgium 6 pot A bodies had disc brakes and big bolt pattern. The American 6 pot ones didnt. Belgium A bodies also had bigger torsion bars and rear springs. Had enough Belgium A bodies over the years
RHD markets went to 4.5 in 1970 with disk brakes on all cars unless you optioned a poverty pack with rubber mats and drums.
they also based their handling package on the same lines as Euro spec barracuda.
