I've got a Hemi in my Hemi!
For everything Superstock related.
At Last!!!
Picked up my engine after the ill-fated blow up about 2 years ago.
A very expensive and frustrating experience but all forgotten now as I can finally start building the Superstock Challenger up.
It will not be a match for Tig's Monster engined Challenger, but at least I can have some fun and dial in a half-decent time.
Yes, yes, YES!!! It REALLY has got a Hemi in it!!!! Just!
Hemi in a hemi.jpg (244.24 KiB) Viewed 10793 times
Yes, it HAS got a Hemi in it....
Hemi Badge.jpg (205.64 KiB) Viewed 10793 times
Here is old faithful after a trip Oop Narth....Bananarama! journey home mind you...
MrNorm
Post by MrNorm »
=P~ =P~ =P~ Fantastic Pete, looks great as it is, and when it's in the Challenger......... :thumbright: :thumbright:
Demon James
Post by Demon James »
Looking good Pete :thumbright: 8-)
Thanks Gavin.
We hadto take the carbs off to get it in and it STILL did not fit.
Ended up taking the carb studs out of the manifold and it went in with a fag paper's clearance.
All dyno'ed up and ready for action.
:twisted: :twisted: :twisted: :twisted:
YeeHarr! :thumbright:
Dutchrunner
Post by Dutchrunner »
Had same issue.
But had 572 cui. Hemi in Volkswagen Golf.
Hemi in Golf
Hemi in Golf
Hemi golf.jpg (114.61 KiB) Viewed 10753 times
69RR572H.XFI
Direct Erection Gold member.
Very impressive, but try getting it in the car when it is assembled.
Dutchrunner
Assembled Hemi does not fit in a Golf.
Had to use transporter van.
What's your hemi specs?
69RR572H.XFI
World Products cross bolted Block.
Stage V heads ported by ICE.
Stage V stainless roller rocker gear.
572ci - 4,5" x 4.5"
8 bolt crank with Chubby size mains.
JE Pistons - 11:1 compression.
Bullet Solid Roller cam - .758" Lift.
Pete Jackson Gear Drive.
Tunnel Ram with 2 x 850 DP 4150 Holleys.
Not great horsepower but a surprisingly high torque figure.
It is going in my full weight Dodge Challenger.
Well, we managed to get one in a Toyota Rav 4 complete with manifold and dominators, but you have to look closely!
Hemi in rav 4.jpg (115.98 KiB) Viewed 10688 times
I have no idea how you managed that, Ivor :shock: :shock:
hemi472
Post by hemi472 »
Ivor wrote:Well, we managed to get one in a Toyota Rav 4 complete with manifold and dominators, but you have to look closely!
You could paint that red and call it 'the little red rav' and be the next Bill Maverick Golden....
hemi472
Post by hemi472 »
Pete wrote:World Products cross bolted Block.
572ci - 4,5" x 4.5"
Sounds like a nice engine Pete - have you had it on a dyno? If so what were the figures like ?
Yes, its been on a Dyno at EDA (great blokes).
It's not going to set the world alight, but it was reasonable.
I was surprised how much torque it made - 720 Ft /lbs! :shock:
Not bad for a Hemi. They are usually revvy but not torquey.
hemi472
Post by hemi472 »
Sounds good , EDA are mega,
I reckon 9.80's - 136ish ??
