Starter motor issues
Fitted a Petronix to the dart tonight and all was going well with it starting and running until I decided to swap the starter motor for a NOS one I bought off ebay to replace the rattly bag of nails that was the old one. Thats when it all went a bit Pete Tong. The starter will spin now but not engage. I took the new motor off and bench tested it and it works as it should, put it back on and same thing, spins but wont engage. Thought "sod it " and fitted the old one back on that I knew was working ( albeit noisey) and it does exactly the same thing, spins but wont engage. Gave up at 10.30pm. ANY IDEAS ???? Please
1970 Plymouth Duster
2000 Dodge Durango SLT
1974 Mk1 Escort RS2000
1981 Chevy G30 motorhome
Plus whatever else is kicking around on the drive
Just a quick question, does anyone know which terminal actually puts power to starter and causes it to throw in, is it the small one ot larger one with lead from starter?
Think it might be trigger wire thats the issue, will replace it tonight, always worrying when its joined with a yellow butt connector. Gonna take the starter off AGAIN tonight to m,ake sure its not locking up, cant see it beinbg a starter issue more the wiring as it does it on both units, even the one that worked 30 minutes before
do you have 2 trigger wires or one
if you have 2 and you put them the wromng way round
the solenoid pulls the pinion away from the flywheel
it doesn't Bananarama! forward
starter still spins
this is based on an Aussie starter that has the FAT power cable
a brown solenoid trigger
a blue solenoid trigger
although the system works with one of them not connected. getting them the right way round with both connected seemed for some unfathomable reason to have an effect
starter still spins
I've got one lead that comes off the main power post that the battery lead goes to and a smaller one from the starter relay. Cant get them wrong way round as the connector on the relay wire is a lot smaller.
