Fuse box
57 Stu
Fuse box
Post by 57 Stu »
Can anyone tell me where I can get a fuse box for a 1970 B body ( roadrunner) ,can't seem to find them listed anywhere . Thanks for any help
Pete.S
Post by Pete.S »
www.painlessperformance.com
They do some good parts if your not bothered about it being identical to the original.
why are you looking to replace?
ANTON
Post by ANTON »
The fuse box is usual attached to the dash harness.
https://www.yearone.com/Product/chrysler-b-body/hu272b
There a few different one. It depends whether you have a oil light or gauge
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
57 Stu
Fuse box
Post by 57 Stu »
Hi,thanks for reply,not to worried about original as my car is a superbird clone! Took it into an auto electrician the other day as kept blowing fuse, on inspection back of box is melted. They told me to get a box and they would fit, I know nothing about electrics but is there any difference in fitting a universal fuse box other than the shape ? Thanks for your help Stu
57 Stu
Fuse box
Post by 57 Stu »
Thanks Anton, I was hopeing to replace the box that is in the glovebox holds 6 fuses , is there another I should check, sorry a bit vague as car not here at moment,cheers Stu
ANTON
Post by ANTON »
You can fit a universal fuse box closer to the steering column. Any 6 or 8 gang fuse box will work and you will need to swap all the wiring over and match the fuse amperage's
http://www.ebay.co.uk/itm/like/26253340 ... 931&crdt=0
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
Pete.S
Post by Pete.S »
might be worth going through all the wiring if its all original than its worth the investment replacing it all..
If the fuse boix has melted I would be looking to check the bulkhead connector as well. Common problem as all the power goes through there to the ammeter and back out.
There have been many fires and loom meltdowns from this.
Steve did a great article on here about bypassing it. Not hard to do, even I managed it.
[quote="MattH"]If the fuse boix has melted I would be looking to check the bulkhead connector as well. Common problem as all the power goes through there to the ammeter and back out.
I`ve just done the same thing on the GTX, replaced the engine bay loom, after the bulkhead disconnect burnt out on the charge circuit, no fire luckily, bypassed the Amp meter and fitted a Volt meter...............much safer :thumbright: :thumbright: :thumbright:
57 Stu
Post by 57 Stu »
Thanks for the advise, will look into that .cheers Stu
