fireing order rotastion
walder
Post by walder »
i have a 383 with mallaroy destributor runs clockwise
Mick70RR
Post by Mick70RR »
The rotor arm on a big block runs anti-clockwise.
GTXJim
Post by GTXJim »
Anti clockwise 18436572
Hell Yeah!! I'm a Redneck
walder
rotation
Post by walder »
even if dizzy bin changed
Smallblocks are clockwise with the dizzy at back of block. Yours should be at the front and run anticlockwise.
walder
rotation
Post by walder »
def clockwise 383 b block got mallaroy dizz on it dizz at front wtf going on
walder
rotation
Post by walder »
come on guys need to use car any help
Don't know what else to tell you, all big block dizzies run anticlockwise, have you changed anything engine wise since it was last running?
I am sure everyone would like to help you, so that you can use the car.
As stated by all the others, all Big Block Mopars the distributor rotor arm turns anti-clockwise. Even a Mopar with the 4/7 swap cam swap, it still runs anti-clockwise.
The same Anti Clockwise Big Block rules apply with std or aftermarket distributor as does the firing order of;18436572.
I run coil packs, which eliminates the distributor, but the firing order also stays the same.
When you take the distributor cap off, does the rotor arm & shaft still feel engaged. As in, you can not freely turn by hand ?
Have you recently removed the distributor ?
Even if you put the distributor back in the engine, but out of time/phase, it should still turn anti clockwise
If you can upload a video clip from your phone via photobucket to this site or post a clip on YouTube with a link. A Short video/film clip is very helpful in a diagnosis situation.
Prothed
Post by Prothed »
May be useful. Block is viewed from the front.
DaveBishop
Post by DaveBishop »
I dont know if this sounds stupid have just bought the engine or have you had the engine running because some small block mopar engines in boats have the it running the other way i dont know if its the same for a big block
2 x 1969 Dodge Darts
DaveBishop wrote:I dont know if this sounds stupid have just bought the engine or have you had the engine running because some small block mopar engines in boats have the it running the other way i dont know if its the same for a big block
Great point, I never even considered boat engines. Guess it's a possibility of a boat engine.
After having a quick browse it would seem firing order remains the same.
Powermyster
Post by Powermyster »
I have a 383 in the roadrunner and have had the dizzy of an played with the timing more times than I care to remember. Definitely runs anticlockwise.
Have you ever had it running? the only reason I can think that it might turn clockwise would be if the starter is turning the wrong way.
Or of the engine is not what you think it is. Post pics or videos
Go big or go home
shovelheadrob
Post by shovelheadrob »
Just a thought, but does the op have a clock that turns the wrong way?
So what happened ? ?
