db's 1970 DODGE A108 Sportsman van
Watch this space... ;)
Re: db's NEW MOPAR...
db wrote:Watch this space... ;)
:GimmePics!:
:D :D :D
Ok, this one is worth a full 10 points... ;)
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161245.jpg
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161245.jpg (165.51 KiB) Viewed 8386 times
1979 dodge Van window, missing connector :roll:
Be an earlier one than that I reckon...
“It’s good enough for Nancy”
The Blue B200 with Centre Lines that's been on Ebay recently?
Not a B200 sorry.
Tho one for 9 points. It'll be a giveaway for Blue I should think ;)
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161213.jpg
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161213.jpg (154.75 KiB) Viewed 8320 times
No guesses?
Ok, for 8 points...
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161248.jpg
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161248.jpg (152.38 KiB) Viewed 8270 times
Beam axle makes it pre '71 so I'm guessing '60's A100 bus.
Blue wrote:Beam axle makes it pre '71 so I'm guessing '60's A100 bus.
Do those have these ribs on the roof,I could not find one,NOT THAT I LOOKED OR ANYTHING :oops:
Not 100% sure but I believe there is a certain amount of ribbage going on....
RW71
Post by RW71 »
Yep, seems to be a bit of similar looking ribbage in this pic............
And you can see the flip out side windows as well....
Blue wrote:And you can see the flip out side windows as well....
Yes and after looking though the patina on the roof I see the resemblance in the ribs/scallops,or what have you, :thumbright:
You got me :D
Close enough anyways... 1970 A108. Aka Dusty Rusteze ;)
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_$_3.jpg
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_$_3.jpg (36.52 KiB) Viewed 8190 times
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161244.jpg
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161244.jpg (151.38 KiB) Viewed 8190 times
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161254.jpg
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161254.jpg (164.88 KiB) Viewed 8190 times
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161120.jpg
C__Data_Users_DefApps_Windows Phone_AppData_INTERNETEXPLORER_Temp_Saved Images_20161120.jpg (176.5 KiB) Viewed 8190 times
