Has anyone done it ?
Wiper motor switch
Wiper motor switch
Is this possible. Will it just fit in as long as I figure the wiring out?
- Can I switch this....
- IMG_5955.JPG (57.06 KiB) Viewed 3656 times
- ....to this.
- IMG_5956.JPG (44.77 KiB) Viewed 3655 times
They also have to match the dash switch the earlier switches had a rheostat,later on they went with a three speed switch,and as mentioned they also had a 2 speed, so they must match up ,because I used a 2 speed on my car got the wiring to work, but as hard as I tried it would not park the wipers.then I found the correct switch it worked for a while, but it never worked right ,so I did have to spend the money and locate rebuilt switch,and wiper motor, now it works great ,some thing like that would be to expensive for you.
You might see if someone can rebuild the motor that came with the car .
Sadly, the 3-speed works on flexi-time. Might do two passes and then just stop. If I'm lucky it'll do three, but it does stop. I've then got to wait a short while and twist the knob back n forth to get it to go again ( for another 3 passes ).kma176 wrote:Is one not a 3 speed and the other 2 speed?? (whats wrong with the 1st one??
Hence wanting to change.
- octanejunkie
It should be fine, if it mounts up and the wiper arm linkage fits, then it should be a simple case of elimination with a meter to find out which wire is which.
You might need an assistant to move the switch while you check which wire is getting 12v at any one time. Make sure you figure out which wire is the earth first or you'll be under the dash replacing fuses. Might be worth having a few spare ones on hand, just in case.
Also, once you have the wiring figured out, just check the rotation of the motor is correct before you connect the wiper arm, to avoid any damage.
So upon closer inspection it seems that I have a 3-speed motor coupled to a 2- speed switch. I think the original build would've had a 2-speed motor, hence the wiring birdnest at the bulkhead (which the previous owner then proceeded to spray all the wires black whilst painting engine compartment and bulkhead)!
So I guess, take the spare 3-speed switch and see if I can mate that to the wiring behind the dash as I'd guess an easier elimination project where I can at least trace wiring colours. Hopefully this will sort the running, stopping and non-docking issues.
Any tips, don't hold back.
