Modern wheels to fit mopar 4.5"pcd
GJUK
Post by GJUK »
Hi guys,
Does anyone know of any modern cheap wheel that would fit a 4.5"PCD large hub type mopar?
Just to move the car around with - so the old dart can have her wheels back :D
Thank you.
Jon
Re: Modern wheels to fit mopar 4.5"pcd
I have plenty of wheels for mopars good for moving arounds £100 for four
GJUK
Post by GJUK »
You're miles from me - it wouldn't make sense to drive to/collect form you for this.
Any other suggestions?
Super Sloth
Post by Super Sloth »
GJUK wrote: Sat Dec 30, 17 11:37 pm You're miles from me - it wouldn't make sense to drive to/collect form you for this.
Happy to act as a half way point if someone is passing through? I'm @ J28 M1
-Jon.
http://www.wheelsupport.com/bolt-patter ... 5-x-114-3/
2 13/16 inch centre bore necessary 71.4mm
most will have no dish
offset will often be too much with the inner of the rim hitting the spring
all L from the list would be ok 0 mm offset some M will be ok 20mm + offset
H probably won't but they may fit backwards for wheeling about
http://www.wheelsupport.com/offset/
Looks like Jeep might be the go....
GJUK
Post by GJUK »
Thanks Sloth :)
Thanks Dave - that is a comprehensive list.
Cheers.
Super Sloth wrote: Sun Dec 31, 17 12:30 am
Maybe you’re sorted GJ?
I bought a 2001 Jeep Grand Cherokee today that came with a second set of alloys with tyres,any use to you?
GJUK
Post by GJUK »
Hi,
I've not found anything yet - drop me a PM.
