Front end rebuild question
freighdog
Post by freighdog »
So, I've read about as much as I can find online about refurbishing the front suspension and made a start yesterday.
Everything was coming apart nicely until I got to the torsion bar. It doesn't appear to have the circlip in the rear mount. The pic shows the rear mount. Is this where the clip should be? Is so, and it is missing, what's holding it in?
Re: Front end rebuild question
It is being held in with the load on it imparted by the Control Arm.
In reality you need a Torsion bar removal tool to do it properly, but if you are lucky you can use a pry bar on the Lower control arm to get things moving.
If you look carefully you will see there is a groove for the Circlip at the back of the housing on the Gearbox Cross member.
freighdog
Post by freighdog »
Thanks Pete, I did think the grooves were for the clip. The mount looks a bit battered, hopefully they've not peened it over to hold the bar in.
Looks like more shopping for me then! :roll:
deppmobile
Post by deppmobile »
I found a tip when I was doing mine where you take a bit of weight off the k member with a trolley jack and it takes almost all the tension out of the torsion bar.
Mine then came out with a few taps on the end with a piece of wood.
Just don't use mole grips on them and a hammer!
Yup. Circlip missing - but it aint going anywhere.
I got mine out by making a long clamp which held about 8" of the bar without marking it. Take the weight of the arm so nothing is in torsion, quick tap and it pops right out. Its not as scary as it seems - 10 min job if you get lucky :)
freighdog
Post by freighdog »
I have the car on axle stands at the sill jack points and there was a disconcerting amount of flex as I lowered the jack off the k frame. :shock: So the jack went straight back up to take the weight of the front end! I'll try raising or lowering the k frame to see if I can relieve any residual torsion.
I've seen the removal tools but was hoping I could manage without one as I am removing the lca's.
Thanks for tips guys.
deppmobile
Google home made torsion removal tools - bits of wood clamped with u bolts etc look like they could do the job for a one off if you really need one.
Playing with the trolley jack should find the sweet spot😁
Wind the adjusters so the bar isn’t under tension. Jack up front under k frame. You can then use clamp tool or the split handlebar Head stock off a BMX around the bar as something to hit with a masons hammer. They come out the back
Sent from my iPhone using Tapatalk
freighdog wrote: Sat Jan 27, 18 12:34 am I have the car on axle stands at the sill jack points and there was a disconcerting amount of flex as I lowered the jack off the k frame. :shock:
Yeah. Mine does that - feels like the car is bending in half. Freaked me out the first time. I too tend to take some of the weight there as I dont like the flex :)
Try owning a Big Block Convertible "E" Body if you want to see body flex.
Whatever you do, don't open the doors....
freighdog
Post by freighdog »
YAY!!
Thanks to all you help and advice, and a little persuasion from 'The Persuader', one side is mostly done.
New UCA is in, LCA is undergoing a rebuild.
You sure thats not mine ? I had to double take ! :)
Well done.
Good stuff,love watching other builds =D>
freighdog
Post by freighdog »
Lovely refurbished lca with new pivot pin and bush, ready to go in.
Lovely job.
Next time you take the torsion bars out it will be easy. I had to take the new ones out to do a starter motor recently and once I took the tension out they slid out by hand. Keep the pics coming
