I sourced some correct chrome trim from Duncan Cannonball to replace the caravan substitute the previous owner used and now need to get the Dutchman panel painted and the vinyl relaid ...... Or vice versa !!!!!
Logic tells me that in order to get the best "line", I should paint first and then apply the trim - only thing here is that the chrome trim runs a lot closer to the base of the window than the previous one did - upside is that I have excess vinyl as opposed to too little. Downside means that I will need to drill new holes (old ones are now filled) and trim the excess vinyl, which is where I may end up scoring a newly clear coated paint job.
Alternative is stretch down and glue the vinyl, get the trim clips fitted, then mask off and bring the paint as close as I can get it so it is just under the trim once installed.
I have seen Challys with the vinyl roof freshly removed and it seems that the latter procedure was the factory way.
Any clues guys ???
