leaf centre pin & axle alignment
Coupe66
Post by Coupe66 »
Hi All,
Had to cut the centre bolts/pins off to separate and rebuild my rear springs on my charger, can I get away with using a cap head/hex bolt rather
than the correct centre bolts.
My other question is how important is the axle alignment on the back end, would there be any 'tracking' issues.
Re: leaf centre pin & axle alignment
Yes you can use a capscrew. Make sure the head is the correct diameter for the spring perch so correct alignment is maintained and you should have no issues.
Coupe66
Post by Coupe66 »
Thanks Blue for your help/advice.
Mike.
