Ram 4x4 third gen rear axle whine
Hi there, just joined so new to the forum. I have a 2002 quad cab Ram with a whining back axle. Had a bearing changed last year and it quietened down but now it's back again. Any garage recommendations in the Chichester area? Need a long enough ramp for the 'beast'. Thanks in advance for your help.
Re: Ram 4x4 third gen rear axle whine
Southern Axle Services are very good but in Watford, so a bit of a trek for you.
Anton in Mitcham is a bit closer, APD Automotive.
Give scott a call he may be able to help you, he works in a garage as a MOT tester 3 days a week in Chichester. He does repairs too. 07725 514249
Thanks for the responses. Much appreciated.
Hi , and welcome.
A lot of Rams were fitted with bolt without “ loctite” on them , causing axle problems.
Sorry. Busy week and memory not so good , but lots of information on the internet.
From memory, it was a bad batch , and not easy to trace by vin numbers etc.
Have a look on line.
