318 poly 1965 rebuild kit wanted/ suggestions
AndyC
Post by AndyC »
Looking to rebuild my 318 poly 1965 back to its original glory (aka stop leaking all over the garage and blowing smoke) looking for someone that either has a rebuild kit or if someone could recommend a good place to get a reputable kit from that would be very helpful, thanks.
Andrew - 07557818515
Part time hvac engineer, full time mopar addict.
1965 Plymouth Belvedere :lol:
Re: 318 poly 1965 rebuild kit wanted/ suggestions
egge machine
they do poly kits
or sonic test the block and if you have good thick cylinder walls bore it to 4 inches and open up a world of pistons
you may find some work needs to be done to the piston crown and/or the edge of the combustion chambers to stop things bashing into each other
anyway
Poly engine resources, enough to make your nose and wallet bleed .... :)
https://autoeducation101.wordpress.com/ ... rces-page/
