68 Charger leaf spring bolts
Matt74
Post by Matt74 »
Can anyone recommend decent quality U bolts for the rear axle/leaf spring?
I need to remove the rear axle so I can get the car onto the frame jig. I'm struggling to undo the nuts on mine and as the car is on axle stands I'm thinking of playing it safe and cutting them off but want to make sure there are high quality ones available first.
I know summit racing do them but I'm not sure of the quality.
Cheers.
Re: 68 Charger leaf spring bolts
Hauser Racing has them in stock, top quality.
Matt74
Post by Matt74 »
Cheers Blue. I removed the spring mounts and shackles in the end. Snapped some studs and had to cut the shackles to get it out.
