Lowering the 2015 challenger
Brucecam1
Post by Brucecam1 »
Hi i am new to the mopar club. I have a 2015 Challenger, It rides about 3 inches above the wheel, i want to lower it to about an inch or so above/ can anyone recommend the right springs to get to get the right stance. Its a 5.7 litre R/T
Re: Lowering the 2015 challenger
Hi there, and welcome to the club.
Unless you can get info off an American Forum where it is more likely they will have done that modification, the only way is to work out the current ride height and the current spring rate. This is done over a range of compression and length by a specialised company.
They can then wind springs with the correct poundage at the appropriate compression rate.
Drop me a PM if you wish to discuss more.
Thanks
