Charger lower sus arm
68Charger
Post by 68Charger »
Is there an adjuster on the lower control arm of my charger for the camber ?
Re: Charger lower sus arm
Lower Control arms have no adjustment in them at all - All Geo is via the UCA and it is a trade off between Caster (preferred) and Camber...
no
but you can use these if you don;t mind the adverse effect of ackerman angle
https://www.manciniracing.com/maracaspkit.html
usually used to set the wheels either at a mental negative camber for racing (double up and long bolts) or to stick them upright on a car with power steering after you have applied the "stick in as much castor as possible **" trick in order to get some weight and feel to the steering
** rear upper-arm cam washer fat side pointing out front upper-arm cam washer fat side pointing in . find the side with the most castor and adjust it to match the the other which for some reason (potentially poor quality control) always has less
not a great idea on a manual steering car....unless you are large of shoulder with the core strength of the hulk
some positive castor is a must self rights the steering when you let go of the wheel, if the steering box fails or the slip joint slips you want to go forward not hard left or right and roll the car.. but you need just enough on a manual. on a power steering car put in as much as you can and re do the tracking and it heavys up the steering a bit
Steve Ottley
Post by Steve Ottley »
You're thinking of the adjuster that sits right at the inner end of the lower control arm and is for fine tuning of the ride height. Wind it in = higher; wind it out = lower.
Some days you're the windshield- some days you're the bug.
